Auto Headlight Function - Pontiac GTO Forums: Pontiac GTO Forum
Old 05-07-2009, 10:44 AM   #1
cowboyili
cowboyili's Avatar
Send a message via AIM to cowboyili
I have an '04 GTO and was wondering if anyone else has had any similar problems with the electric switch for the headlights. If I leave my switch on "Auto," sometimes it does not kill the headlights when I remove the key from the switch and lock the car. Other times though, it does work properly. I've noticed that if it's not working, I can turn off the car and put the switch to off. When I start the car again, usually I can freely move the switch from Auto to Off and it will work properly - but I was just wondering why it would do this and if anyone has swapped out small parts and fixed the issue before??
cowboyili is offline   Reply With Quote
Old 05-07-2009, 11:35 AM   #2
Haven't had that problem in my 04. Wiring or fuse issue???
Old 05-07-2009, 01:32 PM   #3
cowboyili
cowboyili's Avatar
Ya, that's what im thinking too. Probably some weird wiring issue. It might be worth trying to replace the switch, but at the same time - it doesnt bother me that much. I just keep it at "Off" normally. Even then, the car overrides it and turns on the running lights. So i guess its not a big deal. My issue must be a fluke...or a bad part or something.
Old 05-10-2009, 08:05 PM   #4
britt06gto
im not having trouble with my outside lights im having trouble with my dash lights
britt06gto is offline   Reply With Quote
Old 05-11-2009, 07:50 AM   #5
Still under warrantee? Could be a fuse possibly.
Old 06-24-2009, 09:22 PM   #6
Sandros gto
Lightbulb Newbie here quick question to anyone
I Just bought myself a GTO here in Ottawa,Canada might be the only one in town and i was wondering... i really like the clarity of the lexus,bmw's,mercedes headlight.....i guess you called them HID's (not much into tech stuff) but if so how can i get in on the GTO and is it already set up for it?
Sandros gto is offline   Reply With Quote
Old 06-24-2009, 09:33 PM   #7
http://www.gremlynsgarage.com/index.php?cPath=21
Old 07-17-2009, 03:06 PM   #8
cowboyili
cowboyili's Avatar
you can find HID kits on ebay for about $50. usually, from what i understand, you have to drill out the old holes for the old lightbulbs, but everyone seems to like them more.
Old 07-22-2009, 01:36 AM   #9
ema
Yup, I found one at e-bay. The price ranges from $50-60. But I found one also at this site where I bought my jba headers.Try checking both. Adiue!
ema is offline   Reply With Quote
Old 07-22-2009, 06:40 PM   #10
the PCM in the GTO is weird. you need to come to a full stop and then turn off the car before you open the door. failure to follow that order can make the headlights stay on.
2004 Blk/Rd M6 (Ziggy) 12.34 ET, 113.55 MPH, 1.82 60ft
Go:
- SD tune - HPT w/LC-1 - SLP LTs - FTI SS HT Cam - Stiffy - SLP UD - 243 Heads - Custom Exhaust - NW 102 TB - FAST 102 - 3.91s w/Spring Kit - DiffTech DS - Fjord 42# Green Tops - Diamond Stg 3 clutch
Handling: GMM Rip Shift - Harrop Cover - Koni's - Hotchkis - Lovells springs - SuperPro - Energy Susp - Pedders - '05 Brakes - 1" widened rear wheels
Show: Tints 55% Fronts, 15% Rear & Rear Sides - '06 Black Tails
Old 07-26-2009, 02:26 PM   #11
cowboyili
cowboyili's Avatar
svede, that's an awesome tip. i bet that's my problem - thank you so much for your input!
