Sierra 6.2L Exhaust questions - Pontiac GTO Forums: Pontiac GTO Forum
Old 02-01-2017, 09:54 PM   #1
AnPeter90
2007 Sierra Denali AWD 6.2L
Engine light is on. Scan tool is showing cat code. Truck has 3" from the Y pipe to a side dump in front of the right rear tire through a Borla 3" race muffler. Y pipe and manifolds are stock. I just changed the rear O2 sensors at 100000 miles, so my thought process is i was wondering if the factory cats were not receiving enough back pressure with the side exit to allow the cats to work properly? And if the case would a header hi flow cat/y pipe set up work better and clear this code. Def don't wanna go back to a boring factory set up Laugh
Any help or suggestions would be appreciated
AnPeter90 is offline   Reply With Quote
Old 02-07-2017, 03:19 AM   #2
JamieD
The only thing I can tell you is all the power comes up from the starter motor.xe tai van dongben 2 cho. Theres fusiable links and a thousand connections. I don't have schematics for the newer trucks. I can tell you this. When you get that 6.0 running correctly it's a strong engine. I'm sure you've done all the basic stuff. Then there are all those power connections and power distribution connections.Good luck I'll pass this on!
http://hyundai3cuc.vn/san-pham/xe-ta...0kg-thung-lung
JamieD is offline   Reply With Quote
Old 02-10-2017, 01:56 AM   #3
MartinL
For the throttle body; use the adapter from torque rush (Dr-X) that module will solve throttle body swap issues. The 58x to 24x swap needs an adapter box from Lingenfelter. Get these two items, and you should start right up
xe county 29 cho dong vang
MartinL is offline   Reply With Quote
Old 02-10-2017, 03:00 AM   #4
AnPeter90
JamieD, MartinL - Thanks for your feedback!
