Skip shift?/Cags removal. - Pontiac GTO Forums: Pontiac GTO Forum
Go Back   Pontiac GTO Forums: Pontiac GTO Forum > GTO Tech > Transmission/Driveline Tech
Old 01-24-2005, 11:14 AM   #1
legionaire
Could some one explian what this product does for the GTO's and what it's benefits are?
legionaire is offline   Reply With Quote
Old 01-24-2005, 01:13 PM   #2
gto_in_nc
What it does is prevent a 1-2 shift under a very narrow (but frequently touched) set of conditions - engine at temp, speed in certain range, throttle less than some %. Details are in the manual. The "benefit" is that it helped GM get better efficiency in EPA testing & avoided the gas-guzzler tax for the M6, IIRC.
gto_in_nc is offline   Reply With Quote
Old 01-24-2005, 05:26 PM   #3
thunderdan
I believe that this feature is known as "computer aided gear selection" or "CAGS" for short. a buddy of mine has a z06 and it is the first thing he changed with a solonoid block-off. does anybody know where to find this for a GTO or will one for a vette work?
thunderdan is offline   Reply With Quote
Old 01-24-2005, 08:13 PM   #4
Nocturn's Avatar
They all should fit, but they are only 20 bucks so it doesn't matter what car you get one for.
2004/2005/2006 GTO > Your car.
Old 01-24-2005, 08:21 PM   #5
forestdweller
This question gets asked about once a month. Perhaps it would be good to add this to a GTO FAQ section of the site.
forestdweller is offline   Reply With Quote
Old 01-24-2005, 09:13 PM   #6
Nocturn's Avatar
How about I make it sticky...saves us the trouble of linking to the FAQ.
Old 05-08-2005, 11:35 AM   #7
bfitzpa1
I had a 2004 GTO with a Tremec and bought a Cags and everything was cool. I traded my 2004 for a 2005 with a 6 spd Tremec and bought the same Cags and the cables don't fit. What gives?
bfitzpa1 is offline   Reply With Quote
Old 05-21-2005, 11:44 PM   #8
MK-Scorpion
:unsure: I haven't found these conditions posted on the forum. So, since I just read the skip shift section of the owners manual, here's what the '05 book says.
1. Engine coolant temperature greater than 196F or 76C.
2. Speed between 15 to 19 mph or 24 to 31 km/h.
3. 21% throttle or less.
That's it. B)
Just my $0.02...
MK-Scorpion is offline   Reply With Quote
Old 05-22-2005, 07:30 AM   #9
mldavis
In practice, this has become less of a nuisance than it used to be with my 96 TransAm. The speed window is narrower, and they have built in some other computer-recognized conditions that prevent you from catching 4th when you need a bit less lug in normal driving conditions.
Having said that, there are a few things you can do to eliminate it altogether without the expense of screwing with the transmission.
1) If you're not in a hurry, shift early out of 1st and 2nd will be there. I do this on a normal, flat take off in city traffic.
2) If you are pushing it just a bit (normal driving), wait for the shift light to go out before upshifting to 2nd
3) You can always eliminate the CAGS by a quick double clutch
4) You can avoid the CAGS resetting by not coming to a COMPLETE stop.
In my normal daily drive, I never engage CAGS with one exception: when turning a corner and heading up a hill, I sometimes forget the speed window and catch 4th. I've since modified my habits and hold 1st until I get straightened out and rev past the shift light.
'05 GTO Impulse Blue / Blue leather M6 (9,000 miles)
'01 GTP Midnight Blue A4 (120,000 miles)
Previous:
'96 TransAm M6 (150,000 miles)
'93 GrandAm GT Quad4 H.O. M5 (210,000 miles)
'89 Olds Calais International Quad4 H.O. M5 (165,000 miles)
'82 Buick Skyhawk M4 (100,000 miles)
'75 Saab 95EMS M4 (120,000 miles)
'70 Plymouth GTX A3 (110,000 miles)
'67 Mustang A3 (220,000 miles) - wife's car
mldavis is offline   Reply With Quote
Old 05-22-2005, 06:03 PM   #10
MK-Scorpion
This is my first experience with CAGS, and as a newb I've actually found it somewhat helpful. So far, it has been a handy tool to keep me from running up someone's backside in traffic or lagging too far behind when accelerating from a stop. Having said that, I should also mention that I've more than doubled my HP & tripled the torque from my last vehicle so major adjustments to my driving habits have been in order. I've also found that following the shift points described in the manual eliminates it also, but its not nearly as fun.
Just my $0.02...
Old 02-09-2006, 04:12 PM   #11
volacious05gto
I installed a skip shift eliminator yesterday from SLP performance since in traffic i kept hitting the 1-->4 shift thing and just would throw me off but so far no problems easy to install and havent had the skip shift thus far.
2005 6 speed GTO Phantom Black Red interior
1970 4 speed 442 Azure Blue
volacious05gto is offline   Reply With Quote
Old 08-21-2006, 03:42 PM   #12
Spyral
Spyral's Avatar
I programmed mine out with HP Tuners.
This is not my life, this is not my home, this is not me. I hate this.
2004 PBM M6 GTO
Mods? Yeah..I got those. LPE GT2-5 cam, Comp 918's, Comp R hardened PR's, Comp R 1.75 RR's, BMR drag bags, SW LT's, LPE CAI, Hardcore-tuned PCM, chambered exhaust, GMM Ripshift, Aeroforce scan gauges, BMR STB and 382HP / 368TQ at the wheels! Best time = 13.000 @ 110 spinning like a mofugger on 01/21/07.
Spyral is offline   Reply With Quote
Old 08-21-2006, 03:58 PM   #13
Mine was programmed out also, only with a Predator tune.
Old 10-06-2006, 08:27 AM   #14
go-go gto
go-go gto's Avatar
skip shift
if the manual said engine temp higher then 196f then would the 160f thermostat fix the skip shift problem?
2005-M6, gm rip-shift, 2.5"cat back spin-tech pro street, amsoil synthetics, sport grill inserts, tint-10% Kooks 1" 3/4 full lengths, high flow cats, lingenfelter CAI
go-go gto is offline   Reply With Quote
Old 10-06-2006, 02:21 PM   #15
No. A 160 F thermostat simply opens at a lower temperature. During driving, the engine temperature is expected to be higher than 160 F.
As far as CAGS removal is concerned, if you plan on getting the car tuned in the future (highly recommended), I would have the tuner turn CAGS off. This would be in lieu of purchasing the hardware for $20-$30.
Powered by vBulletin®. Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
