TRAC OFF Message - Pontiac GTO Forums: Pontiac GTO Forum
Old 05-16-2006, 08:24 PM   #1
sstoor
TRAC OFF Message
I just installed a K&N Filter on my 2006 GTO. Upon firing it up the TRAC Message came on the display. How do i clear this?
sstoor is offline   Reply With Quote
Old 05-16-2006, 08:33 PM   #2
Did you add a drop-in K&N air filter, or a K&N cold air induction kit? It s really quite peculiar that you would experience what you have described just by fletching around with the air filter. You by chance did not knock anything loose?
Old 05-16-2006, 09:04 PM   #3
sstoor
TRAC OFF Message
It is a cold air box K&N # 63-3053. I went over all the connections just to double check. The only connection that was unplugged was the mass air sensor connection. This is very puzzling.
Any more information greatly appreciated.
Old 05-16-2006, 09:13 PM   #4
Have you tried disconnecting the positive battery cable for a few minutes and then reconnecting? This technique is similar to the MS 3-finger salute used in conjunction with old PC's.
Old 05-16-2006, 09:15 PM   #5
sstoor
I'll try it right now!
Old 05-16-2006, 09:24 PM   #6
sstoor
No dice still TRAC OFF Message displayed and unable to activate with the T/C button.
Old 05-16-2006, 10:13 PM   #7
I would check to see if you inadvertently knocked something loose. I know that you indicated that you had double checked the connections, but I have read too many times about something simple that was missed. Please take a careful, third look.
You mentioned that the only connection you messed with was the MAF. When I put my in my K&N CAI there was another connection that was made in the elbow of the pipe/tube connecting the MAF to TB. Does your's have this connection, and is there something connected to it?
Old 05-17-2006, 08:17 PM   #8
sstoor
Trac Off Message
I went over the connections again and found a bent pin at the MAF connector. Thank you for the advise to stick with it and recheck the wiring. Much more responsive with the K&N Filter.
Old 05-17-2006, 08:19 PM   #9
sstoor
Do you think I need a AMW Catch Can now that I installed the K&N Filter?
Old 05-17-2006, 08:45 PM   #10
Excellent! I am glad that it was something simple. If it wasn't simple, the next thing I was going to ask was if you put the MAF in backwards.
Old 05-17-2006, 09:05 PM   #11
I don't believe the catch can is absolutely necessary with or without the K&N. I installed the catch can because I liked the concept. The interesting thing is that after a couple of thousand miles I have knocked out a quantity of condensed oil in the order of magnitude of a teaspoon or two. The oil drained from the catch can was reasonably clean, with no visual signs of contaminants. This does not mean that they do not exist, only that I could not detect them. Without a catch can I am not certain what length of time, or number of miles driven, is required before deposits build to such a point that performance of the car is actually reduced. So, if you have some money to burn and like the looks of the catch can, go for it. Otherwise, I do not know that I would worry about it. If anyone else has an opinion, feel free to interject.
