Steering wheel shake - Pontiac GTO Forums: Pontiac GTO Forum
Old 01-15-2008, 10:27 AM   #1
surfinjoe
Unhappy Steering wheel shake
I have an 2004 GTO A4 and I am getting a bad steering wheel shake from 60 mph +. I am also getting un-even tire wear on the front tires. It looks like the car may be toe'ed in. Does anyone have any experience with this issue?
surfinjoe is offline   Reply With Quote
Old 01-15-2008, 11:07 AM   #2
Take to a shop and check your alignment.
Old 01-15-2008, 05:49 PM   #3
Ditto
Old 01-15-2008, 06:33 PM   #4
GT O yea
GT O yea's Avatar
Shake and Bake!!!!
I heard of uneven wear on the rear, do to the Euro style chamber, but the fronts are even keeled. I had a little head shake when I first bought mine, took it down got the tires balanced and the head shake went away.
GT O yea is offline   Reply With Quote
Old 01-26-2008, 10:21 AM   #5
asktk
alignment or wheel balance - unless it only happens when you apply brakes - then warped rotors.
asktk is offline   Reply With Quote
Old 01-26-2008, 01:35 PM   #6
Not knowing anymore, I would have to agree. I would question whether or not the steering wheel vibration occurs all of the time or just within a specific range of speed?
Old 01-26-2008, 11:00 PM   #7
Does your car sit a lot? I have noticed that BOTH my GTOs had this problem, when I'd first start driving them after they'd sat for more than a week. These cars are HEAVY and they tend to flat spot the tires when they sit a lot. This is a fact. Usually when this happens to me, it eventually smooths out as the flat spots go away....after driving 20 miles or so.
On the other hand, the GTO's front end is kinda famous for being "fragile"....if you've hit anything with it, hard bump, pothole...etc, you've prolly knocked it out of whack. Also, you could have a bent wheel. Could be a lot of things. First thing I'd check though is tire/wheel balance, since your symptoms are speed-related.
Old 01-28-2008, 10:36 AM   #8
surfinjoe
My car sits alot and it does get flat spots on the tires. This should go away after a while. My wheel shake sometimes happens after two hours of driving. In Michigan we have many pot holes and maybe my GTO found one of them.
Old 02-15-2008, 07:17 AM   #9
aussie_muscle_fan
aussie_muscle_fan's Avatar
that can all be the prob too but the way the gto was designed in the front end yes is very fragile u could of cracked ur balancer from rough roads or the way its driven and centre bearings can play a part in it too i had one come into the shop here one day with a very similar prob it couldnt take his driving and it actually snapped the rear engine mount and cracked the balancer.. but yeah i could be wrong but it is wise to get it checked out cuz it can make ur alignment go out of wack as well wich might explain the wear on the tyres too
if it aint holden or chrysler than it aint worth driving
aussie_muscle_fan is offline   Reply With Quote
Old 08-21-2009, 11:55 PM   #10
xtranaut
Aussie
What is this magnificent red devil in your photo? I wish they had done THIS design in the 04 comeback GTO. I HAVE GOTTEN USED TO THE BODY STYLE OF MY CAR only because the interior is so nice that it makes up for the rather unthreatening exterior.
THIS CAR LOOKS VERY EURO..touches of BMW and AUDI and nice big wheels to give the car a thrusting look...BUT STILL NO SUNROOF!
xtranaut is offline   Reply With Quote
Old 10-28-2009, 01:41 PM   #11
crug75hid
Oh, Very nice look of your car, It's superb aero dynamic shaped and mac wheel tyres. Entirely pretty attractive with it's colour too.
crug75hid is offline   Reply With Quote
Old 09-17-2010, 12:05 PM   #12
leahsLS2gto
leahsLS2gto's Avatar
Originally Posted by davidhill View Post
Your front rotors are warped and need to be removed and resurfaced.Price for that job could go from about $110.00 to about $160.00 depending if it needs brake pads.If it does be sure to buy the good pads.
I am having the same problem with my gto m6 its shakes above 55mph and gets very rapid when i hit the breaks all the way down untill about 20 mph, n high speeds its almost unbearable to sit in the car. Is this the same problem im facing?
2006 LS2 GTO M6
Volant Air Intake
Flowmaster Exhaust
Diablosport Tune
Kooks Headers
leahsLS2gto is offline   Reply With Quote
