GTO Fuel Smell = Rusted Tank - Pontiac GTO Forums: Pontiac GTO Forum
Old 02-07-2013, 06:38 PM   #1
somethingelse
somethingelse's Avatar
In enjoying my Goat daily since July 2004, I am finding some things ahead of others on this model. I did not expect a rusted out fuel tank in this day and age however.
It started with a fuel smell in the interior, that appeared stronger in the trunk. I didn't see anything reaching the ground, so I expected a bad seal or something from my pump install years ago. In pulling it out, I found the tank had rusted, allowing fuel to seep through the metal.
It appears that debris and water can enter the tank containment enclosure from underneath where the fuel line access is. Not a biggie for a coated tank - except that I am finding that vibration has removed the coating to bare metal in areas along the bottom of the tank.
These tanks are very expensive, so here is a link that shows how to remove and protect or replace it. It is well worth the effort if you actually enjoy your Goat daily like I do.
http://www.mycarfling.com/#/Event/In...f-7fdd89abee16
04 PBM - M6
Forged 347, 59cc AFR205's, AFR 6016 w/1.8 YT, UDP, Kooks SS LT's, Magnaflow, FAST102/92,GMM, BMR, '05 hood, '06 Calipers/DBA, MPD Splitter, Pedders, CSL Wheels, SPEC, Svede, RPM Level IV, E85
Kim
06 IBM / A4
STILL Stock
somethingelse is offline   Reply With Quote
Powered by vBulletin®. Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
