What heads to buy - Pontiac GTO Forums: Pontiac GTO Forum
Old 01-22-2009, 07:04 PM   #1
Ghost Rider
Question What heads to buy
Does anyone know anything about livernois motorsports heads and cams good or bad thoughts would be helpfull or any suggesions on other brands
any help would be good
Ghost Rider is offline   Reply With Quote
Old 01-24-2009, 01:07 AM   #2
That is a good company. Though I've yet to see anyone in the top GTO ETs talking about them.
Old 01-26-2009, 06:59 PM   #3
Trick Flows are arguably the best but because they change the valve angle it's a bit of a fuss with pushrod length and such to fit them in. the best drop in for a street/track car are AFR 205s but they are equally pricey
2004 Blk/Rd M6 (Ziggy) 12.34 ET, 113.55 MPH, 1.82 60ft
Go:
- SD tune - HPT w/LC-1 - SLP LTs - FTI SS HT Cam - Stiffy - SLP UD - 243 Heads - Custom Exhaust - NW 102 TB - FAST 102 - 3.91s w/Spring Kit - DiffTech DS - Fjord 42# Green Tops - Diamond Stg 3 clutch
Handling: GMM Rip Shift - Harrop Cover - Koni's - Hotchkis - Lovells springs - SuperPro - Energy Susp - Pedders - '05 Brakes - 1" widened rear wheels
Show: Tints 55% Fronts, 15% Rear & Rear Sides - '06 Black Tails
Old 01-28-2009, 04:54 PM   #4
NEXSTAR7
hey ghost rider . wich heads did you go with? i just purchased the stage 1 heads with the stage 1 cam. I'll let you know how it goes.
Lingenfelter cai , Vararam throttle body spacer, V-Max ported and polished Throttle body. SLP long tube headers, high flow cats, x pipe, Flowmaster 40's mufflers, Quick time performance exhaust cutouts. Livernoise stage 2 heads and stage 2 comp cam , Pedders suspension upgrade. Dyno to 434 rwhp.
NEXSTAR7 is offline   Reply With Quote
