camaro wheels on gto - Pontiac GTO Forums: Pontiac GTO Forum
Go Back   Pontiac GTO Forums: Pontiac GTO Forum > GTO Tech > Appearence/Ground Effects/Wheels
Old 12-29-2008, 09:41 AM   #1
04ImpulseM6
Will 00-02 camaro ss wheels fit on an 04 gto? The ss wheels are 17x9 with a 6.875" backspacing. What is the factory 17" backspacing? I can't find much info except on the bolt patterns. My real concern is the tire size and rubbing the front strut. Also, any recommended tire sizes? I want to do a 275/40-17 rear. Thanks.
04 GTO Impulse Blue/Blue Leather M6
04ImpulseM6 is offline   Reply With Quote
Old 12-29-2008, 07:38 PM   #2
salbracht
Short answer ... no. The bolt pattern is different and the GTO was not made for wheels of that width (9 inch) ... they would rub unless you rolled the fenders.
salbracht is offline   Reply With Quote
Old 12-29-2008, 08:59 PM   #3
GOD DAMMIT, stop saying this, have you, yourself ever put a set of F-body rims on a GTO? They fit perfectly, the difference in bolt pattern is about the width of a few playing cards. The holes have more play than the difference in bolt pattern. I've ran T/A rims on mine around town and launching at the track with over 550 ft r/w torque on spray, over and over again, well over 100 passes on these rims.
My T/A rims are 8", I don't know if the offset will work with a 9" Camaro rim. Plenty of people have put 10" rims on the back without any modifications, check out the 19" x 10" CCWs, they fit perfectly, saying a 9" rim won't fit is a very broad statement.
So no one can generalize and say they won't fit, try them and let others know. There are plenty of others in the top ET lists for GTOs running F-Body rims.
Powered by vBulletin®. Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
