removing front rotors - Pontiac GTO Forums: Pontiac GTO Forum
Go Back   Pontiac GTO Forums: Pontiac GTO Forum > GTO Tech > Maintenance Discussion
Old 03-04-2010, 01:05 PM   #1
andyx181x
Hey guys, could use some advice if there are any special tools needed to remove the front rotors; going to install new brake pads tomorrow with my uncle but were going to resurface the rotors as well. Anyone can tell me step by step what to expect would be great.
andyx181x is offline   Reply With Quote
Old 03-04-2010, 07:23 PM   #2
After you remove the caliper. You will have to remove the caliper bracket. It's just two bolts, 18 or 21mm I think. Then the rotor should slide right off. If not then some persuasion will be necessary. It's just some rust between the rotor and hub. Rotate the spindle while giving the rotor some love taps with a soft mallet. From the inside hitting out.
Old 03-05-2010, 10:11 AM   #3
HP11
HP11's Avatar
Originally Posted by cncmasterofor View Post
...18 or 21mm I think.
They are 21mm. 13/16" will also work.
2004 Ford Ranger Edge (Daily Driver)
2005 Pontiac GTO (My Car)
2014 Kia Rio LX (Wife's Daily Driver)
2010 Mercedes Benz C300 AMG Sportline (Wife's car)
(Not sure if that was ever really true...but what a joke it is now!)
HP11 is offline   Reply With Quote
Old 03-06-2010, 12:10 AM   #4
andyx181x
THanks for the info guys, everything went well today but wow the rust on the hub was strong as hell! We had to beat the hell out of the rotor with the rubber mallet, I was surprised with the level of rust on it.
Powered by vBulletin®. Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
