Rearend Removal, illustrated - Pontiac GTO Forums: Pontiac GTO Forum
Go Back   Pontiac GTO Forums: Pontiac GTO Forum > GTO Tech > Transmission/Driveline Tech
Old 07-15-2007, 05:33 PM   #1
Lightbulb Rearend Removal, illustrated
Ok, I have been threatening to do this for a longtime, so here it is finally. A few weeks ago I ordered a set of 3.91s and a Harrop cover for my GTO. I decided that I was going to do a step by step how-to on the rearend removal and eventually the gear installation.
Pic of the car on jackstands, exhaust already removed:
Here is a pic of the tools you will need, a rachet with an 18mm socket, a medium sized adjustable wrench (or an 18mm wrench, I didn't have one handy), a 15mm wrench, a 17mm wrench (and another one to use as a cheater), another rachet with short extension and a 13mm, 14mm and a 15mm DEEP socket, an 8mm allen and a 5mm allen:
You will also need a foor jack and some jack stands.
In this pic, you can see the torx head bolts on the pinion flange. I do not know what size these are exactly, but a 12 point 14mm socket it fits it perfectly. Works good. You will have to remove all 6 of these bolts. 3 have the torx heads and the other three are 18mm with locking nuts on the back side. The center support for the driveshaft has two 13mm bolts. Once all the bolts on the pinion flange are removed and the center support mount bolts, the entire shaft can be removed. You have to wrestle with it a bit to get it past the nipple on the pinion gear, but it'll come. You need to force it forward as much as it will go once its unbolted from the pinion flange.
Here are the forward (upper) mount bolts. There are two, they are 17mm. It is easier to get to them after the driveshaft has been removed. I used a regular 17mm wrench with an 11/16 doubled on it as a cheater.
There are a total of FOUR of these bolts on top of the rear subframe. The rear upper two can't really be seen until you unbolt the rear mount and let the entire assembly down. Then you can get to them, also 17mm. I used the same double wrench technique to get them loose. You have to have all four of these bolts out and the four bolts that hold the rear mount in place in order to get the rearend out. There's also a vent pipe up on top that you will have to disconnect. Below is a pic of the rear mount, the four bolts are 13mm:
Next, you have to remove the antilock brake sensors and unbolt the half shafts from the stub axles. The ABS sensors have a single 5mm allen holding them in and the half shaft bolts are 8mm allens.
Now, once you have all this unbolted you can easily remove the rearend. Keep in mind that you will need to keep it supported on a floor jack while unbolting the mounts. I unbolted the half shafts and all the other stuff first, then did the mounts last. Unbolt the forward upper mounts first, then the rear mount, then you can let it down to get to the top rear mount bolts. Once they are out, it'll come on out. This job took me 45 mins from start to finish and that included removing the exhaust.
PM me if you have any questions.
Old 07-15-2007, 06:59 PM   #2
Wretched 6.0
Wretched 6.0's Avatar
Send a message via AIM to Wretched 6.0
nice, I have an extra one of those sitting in the shop waiting for me to get rich and put a set of gears in it.
Performance - GMM Ripshift, Volant CAI, Kooks 1 3/4 LT's w/Offroad Pipes, Magnaflow Cat Back, HP Tuners
Appearance - 17x8 ASA AR1 Black
Tires - 245/45/17 Bridgestone Potenza RE01R
Comfort - Sirius Sportster5
Handling - Completely PEDDERIZED Suspension
Wretched 6.0 is offline   Reply With Quote
Old 07-15-2007, 08:17 PM   #3
lol, tell me about it. I just dropped 9 bills large on a gear and a harrop cover.
Old 07-15-2007, 09:32 PM   #4
andyx181x
mind taking pics of you showing how was before and after you install your new gears? i never really seen the inside of it before
andyx181x is offline   Reply With Quote
Old 07-15-2007, 09:44 PM   #5
Thanks for the pics and the writeup. This is a valuable tool for those who will do a gear swap. Can we expect further threads with the gear install?
Old 07-15-2007, 09:57 PM   #6
Yep, planning on doing the same kinda writeup on the gear installation, so stay tuned. I don't have my gears yet, but they are on their way.
Old 07-16-2007, 12:22 AM   #7
andyx181x
whats the advantage your going to have with these new gears?
Old 07-16-2007, 01:49 PM   #8
Changing the final drive gear ratio is the single biggest improvement you can make to the "seat of your pants" feel of your car. Going from a 3.46:1 to a 3.91:1 ratio will give the engine a better mechanical advantage on the rear wheels and also relieve stress from the clutch, transmission and driveshaft. (Increases stress on the axles). In other words...instead of only being able to spin through 2nd gear, I should now be able to continue spinning well into 3rd gear. lol. Get it?
Old 07-16-2007, 06:17 PM   #9
andyx181x
wow so it sounds like the engine in a way got more "grip" on those wheels to project power, am i wording this correctly? hows your milage going to be? also does that shave off some time on the 1/4 mile?
Old 07-16-2007, 06:24 PM   #10
you are correct, it will shorten the 1/4 mile time and decrease the mileage as well, since the cruising speed RPM will be increased.
Old 10-16-2007, 12:51 AM   #11
panamadave
I want to go the other way
I want to go the other way, and up the ratio to about a 3:07 with my automatic. How about swapping in a complete third member? If you don't mind, what did the gears cost, I haven't seen them advertised.
panamadave is offline   Reply With Quote
Old 10-16-2007, 11:03 AM   #12
QSMGTO
WOW! Great pictoral instructions. Much better than those in the DIY manuals like Haynes and Chilton.
QSMGTO is offline   Reply With Quote
Old 10-18-2007, 02:06 PM   #13
Gears are expensive. And I assume that you have no intentions of increasing performance with 3.07 gears...yuck. You'll spend at least $600 on the gearset, no matter what the ratio.
Old 10-03-2009, 08:53 AM   #14
Fixed.
Old 07-10-2014, 11:36 PM   #15
keitho64
I know this is an old thread but thank you for the excellent write up.
Keith
05 GTO
69 911
64 Corvair
keitho64 is offline   Reply With Quote
Powered by vBulletin®. Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
